46-racing
WHAT SIZE IS THIS LIFT KIT?
I'm a new member since my other half recently bought a '93 Club Car DS gasser. We ASSUMED it was a 6" lift, but from all of the research I've done (mostly trying to figure out why the tops of the front tires were angled out) its just not adding up.
Here's what we THINK we know.... The previous owner put the 1 1/2" homemade spacer bar on top of the front leaf spring to get rid of the grinding noise he heard after putting 12" rims on with 22x11-12 tires (is that the correct size for a 3" lift?); he also had the A-arms in the outer hole on the top A-arm mounts. We moved the A-arms in to the inner hole to attempt to correct the angled tires, & psi is set @ tire mfr size of 5psi instead of 18. Now the tops of the tires are turned IN though.
The rear leaf spring is above the axle, and the spindles & also the rear spacer blocks look similar in size to those from Jake's 3" kit. BUT the spindle itself has the #6230 stamped into it (the Jake's 6" spindle lift kit part #) and the Jake's emblem isn't on them.
We've tried aligning the cart but NOPE. Any suggestions on WHAT THE
we should be looking for or doing??
After 3 days straight of surfing the web & hunting through forums, I'm finally sending out the SOS signal. Please, fellow Cartaholics members, make sense of this probably simple issue for us!
Thank you in advance for any & all help!
