Changing Oil in a EZGO RXV Electric Golf Cart Rear End:
1. Remove bolts securing the oil pan.
2. Using a rigid gasket scraper and the hammer separate the oil pan from the axle.
3. Remove all traces of the old gasket material from the both surfaces and from the bolt holes.
4. Clean oil pan after emptying the old oil.
5. Apply Permatex RTV or equivalent to the gasket flange on the oil pan according to product instructions.
6. Install the oil pan, tightening the bolts finger tight and then tighten to the proper torque value in a cross bolt pattern.
7. Check axle for Fill plug, if a fill plug is present skip steps 8-16 and follow the fill procedure for axles with fill plugs.
8. Remove the driver side rear wheel as shown in the Tire and Wheel section of this manual.
9. Remove the driver side rear hub as shown in the rear hub in the next section.
10. Remove the driver side axle shaft as shown in the next section.
11. Thread flexible tubing into the axle tube, past the seal and into the gear area.
12. Connect the flexible tubing to the fluid pump.
13. Fill with 25 oz. of Mobile 424 lubricant slowly.
14. Install the axle as shown in the next section.
15. Install the rear hub as shown in the next section.
16. Install the rear wheel as shown in the Tire and Wheel section of this manual. Fill Procedure For Axles Fitted With Fill Plugs.Latter model axles have a fill plug located on the driver's side of the axle. Remove the fill plug, insert the flexible tubing and connect the other end of the tubing to the fluid pump. Fill with 25 oz. of Mobile 424 or equivalent lubricant slowly and replace the fill plug.
