Invisabull
2000 Club Car 48 volt golf cart. Within last six months forward and reverse switch replaced and new solenoid. Reason for replacement is at times when I stop it fails to run again, no solenoid click sound at all. If i pull it back to my yard where I can work on it, it seems start working again and when its working everything is fine. This was purchased about 7 years ago so others have worked on it. Comparing the wiring diagram there is a black and white wire coming off the forward microswitch to primary circuit on solenoid. Mine only has the red and yellow wire. Also the wiring diagram shows two resistors, mine has only one across the secondary circuit (heavy cables) ... preshate any help given
