Brake Light Not Working
Rjuarez
Hello all,
Newbie here I bought a 2014 Club car Precedent 6 seater electric. I am looking to add/activate a brake light. I pulled up the floor and the wires are ran and the pedal was plugged in however it did not work. Any ideas of where to tap into to the brake pedal/pad to work? Is there somewhere to tap into in the front of the car?
Please help thank you in advance.
The pressure pad has probably gone bad like they always do, try plugging the two wires with bullet connectors on the golf cart end together, if the brake lights turn on it's the pad. You would either need a new one or get a mechanical brake switch
See if you have voltage when measuring between the red and black wires on the golf cart end. If not, there is a relay behind the dash that turns off the brake lights with the key off. This may be the culprit, test for voltage coming into the relay and 48v across the two coil terminals with the key on. Also make sure you have continuity through the circuit breaker/fuse if there is one in the pedal box
Thank you, so no power at the red and black wire from the car side. What would that relay look like? Sorry I have the dash open I see the box I just added for the blinkers, and what not.
There is nothing connected to the coil terminals to turn the relay on
Not sure where the wires are that are supposed to go there, maybe the red and orange? The wires should give you 48v with the key on. Alternatively you could just connect the blue and green wires together and then you will have brake lights regardless of key position
