My 97 TXT would not start and run unless the choke was fully on. I cleaned the carb 3 times. Same symptoms. Ordered a new carb on amazon. Now it starts easily and runs well on flat ground. It will not rev high enough to go up any type of hill.
I checked valve lash and set all at .004. Spark is good at both cylinders. Compression test is 90psi on each cylinder using a Harbor Freight compression guage. I also adjusted the carb jet. Still no improvement.
Is there anything I am overlooking?
Thanks
Thanks
