1lakevernon
have a briggs with external jugs tight fit but made it 1 inch shaft how wide of a belt do i use or is it standard size, and how much slack do i allow for when measuring for a belt. also was running fine then blew a fuse and every time you try to start it it blows another one have power to the syln and when you turn the key ign and relay both power up but will not power the starter you can jump across and it starts fine and dies when the key turns off is it the syln that is bad?
