G'day, I reckon your out of luck as the ignitor would be replacing the stator coil. I don't think you can directly send a current straight from your battery to your ignition coil. But who knows?, i'm just a golfer!!!. Good luck anyway. Logic tells me you need to create timing with the spark plug, that's why you get your pulse coil working with your ignition coil so to time the spark, so to speak?. But with this type of wiring your power comes from the battery being continually charged from the starter generator. which feeds into the ignitor releasing to the ignition coil by the pulse coil which is attached to the magneto. Could be telling a whopper?
