Spring Farm
Cart was running, going downhill when it quit and this is what we have found.
With key off, F/R in forward, tow /run in tow. Big terminal on solenoid has 50V on inlet side, other big terminal is 0V.
Key off, F/R switch in forward, T/R switch in run, terminal inlet on solenoid is 50V, other terminal on solenoid is 50V. Small terminal on solenoid is 50V. Motor at A1 and A2 have 50V while F1 and F2 have 0V.
Key on, T/R switch is on tow, F/R switch is on forward, large inlet terminal on solenoid has 50V, motor ar A1 has 50V, A2 has 5V, F1 has 5.2V and F2 has 0.1V.
Key on, T/R is in tow, inlet on solenoid has 50V and outlet has 50V, small terminal on solenoid has 50V. MotorA1 has 50V, put F/R in reverse, press accelerator A1 has 50V, A2 has 50V, F1 has .1V, F2 has .1V.
Any solution is appreciated,
Spring Farm
Spring Farm
