I think they make spindle lifts for that model although I would highly recommend against that type. I dislike spindle lifts in general because you are basically putting a giant lever arm on your suspension and the bushings will wear to nothing in short order as a result. You add brakes to the mix and now the forces are 10 X more from the braking torque.
I would suggest contacting Allsports, they manufacture the OEM lift used by Club Car on the 6 passenger Onward which uses the same front drum brake setup. I believe they make lifts to order, if so they could easily mix and match the parts to make a DS A-arm lift with the necessary brackets. The spindles are pretty much the same, the difference is which steering brackets they weld on. Wouldn't be hard to weld on the Onward brake brackets while they're at it.
