Golf Cart Wizard
The controller not the v glide.
Wait so does it start at full throttle and slow down as you push or does it start at 1/2 throttle and increases as you push down?Push pedal down a little ways and motor goes at a fast speed and spins the tires. As I continue pushing, it slows down but not real slow
Is the half-speed reverse resistor really necessary?When I first started testing (with the black and white wires disconnected from the micro-switches) many posts ago, I was getting a zero reading with no pedal. As I pushed it down, it started at 960 ohms and went up to 5000 ohms. Plugging and unplugging the black wire, the little half-speed reverse resistor connection broke in the black wire. I cut it out. What do I purchase to replace it?
No that’s why I said just eliminate that to make sure the resistor or those wires aren’t somehow causing a throttle fault.Is the half-speed reverse resistor really necessary?
I deleted the half-speed resistor with a solid black wire. NOW what am I looking for to solve this problem?No that’s why I said just eliminate that to make sure the resistor or those wires aren’t somehow causing a throttle fault.
What do you mean deleted? As in you took the wire out of the circuit or you spliced a wire in its place to complete the circuit?I deleted the half-speed resistor with a solid black wire. NOW what am I looking for to solve this problem?
Well that might just be your problem. The half speed circuit is either supposed to not be connected or be connected in series with the 5k ohm resistor. If you put a piece of wire in place of the resistor now you've created a short circuit.I cut the complete half-speed resistor out and replaced it with a solid black wire. NOW....the wire coming from the V-glide to the micro-switch is a solid black wire (no resistor).
Just looked on eBay at Ohmite Brown Devil B12J5K0, 5K Ohm 12-Watt Wire wound Power Resistor. What wattage do I need?I was not getting an ohm reading testing the V-Glide two days ago. Up until two days ago, I was getting a reading of 960 ohms to 5000 ohms. I discovered the half-speed resistor wire was broken. I replaced it with a solid black wire two days ago going from the V-glide to the Micro-Switch. The original problem exists and still does with my first post on March 4, 2024.
Where do I purchase the right size (what is the size) resistor for the half-speed circuit? When I put the resistor back in the black wire going from the V-glide to the Micro-switch, I will have the same problem (push pedal down 1/3 of the way and it takes off super-fast). It is very dangerous to drive!!!
