I just put a RHOX 6" drop spindle kit on which is identical to Jake's. I'm having a issue with camber the toe seems to be right on. I have a positive camber about 5/8" on both sides. Any ideas of and attachment that can be put on it to correct the issue. If there was an attachment up at the top where the shock is connected that would probably fix the issue. There's also room at the top of the bracket where the bolt is connected to the shock that another hole could be placed to pull the top part of the shock in.
