I have a 2003 48 volt Yamaha electric golf cart.
Just stopped, I have new batteries, light to my head lights work , I hear the solenoid click yet when I press accelerator no movement. Could that it be a bad tow switch… any ideas?
Thanks Bob
If the switch was bad the solenoid would not click. check the voltage on the big terminals of solenoid with pedal depressed , one should be about pack voltage and the other almost zero. If not solenoid may be bad. Also check the F&R switch and make sure it is good. Get back to us on results.
Hi Zman,
This one is for the books! I did a meter check on tow switch - it was good. So I took off floor mats and metal plate to check the accelerator micro switch… in between the micro switch were 3 utility blades wedged perfect between them which must have fallen out out the front storage compartment ! I removed the blades and everything works perfectly!
Thank you for your initial response. B
