Yamaha Rear End Gear Oil Leaking From Vent Tube
jeffkoch1
I have a 1998 Yamaha g16 gas cart and the gear oil is leaking out of the vent tube on the axle tube next to the rear end cover I have drain the oil and put in the exact amount of oil back in and it still leaks I use the cart at a campground and after about two day I have to add fluid ,I can't fine any answers yet can anyone help Thanks Jeff
gibby
Had a simular problem, found I needed to make sure vent tube was pointed straight up coming out of the housing, then a 180 bend down. worked for me. Gibby
