Yamaha G29 Charging Cable Help Needed
moorenycc
My son accidentally tripped and pulled the charging cable out of the charger this evening and I need help identifing which cables plug into which pins inside the charger. There are 3 cables - a red, black, and white. There 3 pins - p4 (bat -), p5 (bat +) and p7.
Can someone help confirm which colors plug into which pins (the black and white cables are thick than the red cable).
Plug charger into cart . With a volt meter check between the red wire and the black wire. Is there 48 volts? If not check between white and black. If white and black has 48 volts the white wire is B+ , Black is B-, red is P7. Or it could be that red and black have 48 volts and Red would be B+ and white is P7. You understand? I really don't know if P7 is even needed as it only shuts the cart off during the charge cycle.
