Hi,
Our 1989 Yamaha G2 has recently developed an engine starting issue. The Cart crawls under the Starter Power but struggles to Fire the engine & sometimes Backfires. Once it starts it Runs fine with no indications that anything is wrong.
I have replaced the Spark Plug (the old one didn't look very bad), Removed & Cleaned the Carburetor (nothing bad in it, float is OK, the Idle screw isn't holding the throttle open, the needle-point adjustment screw is open 1.5 turns), Replaced the Fuel Filter & it has Fresh Gas. Also Checked the Coil (4.5 ohms).
Basically I can't find a faulty part & don't know what to Check next.
Appreciate any Guidance.
Thanks,
Jim
Thanks,
Jim
