Finally got my 1987 Yamaha G2 to run and drive and have spark. I’m not too familiar with the “starter generator” charging system. I’m assuming it works like other charging systems where the “starter generator” is similar to a stator? Then sends power to the voltage regulator and then from the regulator to the battery. I put my volt meter on the battery and has 12.43 volts. Put it in neutral and get the engine to run and it drops to 11.43 volts. To me this sounds like it isn’t charging the battery. When probing a green wire on the regulator it only has 9.4 volts. I guess my question would be does anyone have the charging system specs?
Appreciate the help.
