Legacy of Bo
Bare with me, I'm a newbie. I'm having battery charging issues somewhere within the charging loop on a Yamaha G2 golf cart. Everything was fine until a few days ago when cable end melted off. I changed everything. The charger does not appear to be the problem, because when I play with the wire attached to the starter? the battery charger will briefly turn on. I'm wondering if this is just a wiring issue, where I need to get new wires, or could this be the starter? Forgive me if I'm not using the right terminology. If you think it's wiring, what specifically do I need to purchase? The only other thing I can think of is I bought some lube that I put on the battery terminals right before this issue occurred. Just looking for some guidance.
