Yamaha G16E Won't Run
walts37
With batteries full charged Key on, forward or reverse, foot feed depressed no clicks or movement
Parked it everything was working great next day no go. I did wash the batteries with the water hose but drove it after that. please give me some ideas I do have electrical knowledge & can read wire diagrams can you give me some hints on where to start. Thanks Walt
walts37
Problem solved Found a switch below the accelerator that was not working, I took it apart cleaned it up got it working then installed it. Hooked everything back up still no GO. Located the fuse removed & checked OK When I reinstalled the fuse I herd some clicks. Must have reset something because it all works fine now. The wire diagram I got on this site was a Life saver Thanks Cartaholics
Walts37
Welcome to the forum...
Glad to hear you found what you need here and got your cart running again...
