coachshalley
Have a Yamaha G16 gas golf cart with a possible starter generator issue. Sometimes battery will charge sometimes it will not. The cart does run without the 10 amp fuse in it. Wiring diagram shows a ground wire from fuse to starter is that correct. Have completely taken off and checked the entire wiring harness only broken wire was the buzzer wire fixed that. Was getting 16+ volts on charge sometimes now down to 14 volts. But not reliable.
