WallysWorld
Hello all, Just picked up a 1980 Yamaha G1 golf cart. It will turn over but it's not starting. I know it has spark, and so do my neighbors (that shock is something else.) The people I got it from ran a compression test on it and said it only had 15-20psi. In reading all the posts out here on this topic it seems as though I should replace the crank seals and the head gaskets. I was going to do the rings too while I have it open. I am not sure about if it is getting fuel, so I am going to get a rebuild kit for the carb and fuel pump as well. My question is where does everyone get their parts from. I have found a few sights but wanted to get some expert advice on this matter. Also any tips and tricks in the work I plan to get done.
thank you.
thank you.
