Resource icon
Yamaha G1 Crank Seal Replacement
HotRodCarts submitted a new resource:
Yamaha G1 Crank Seal Replacement - Replacing Crank Seals on Clutch and Flywheel Sides on a Yamaha G1
:yamaha:
Replacing Clutch Side Crank Seal:
1 - Remove the gas tank.
2 - Remove the outer clutch cover by removing the phillps head screw.
3 - Remove the bolt with 7/8 head holding the outer clutch plate and remove the outer clutch plate.
4 - Remove the drive belt and starter belt.
5 - Using a clutch puller remove the inner clutch plate/shaft.
6 - Remove the oil pump gear housing and...
Read more about this resource...
