yamaha electric 48 volt no power when switched
timr495
golf cart just died in woods while riding but 2 times before it slowed and would barely pull itself then it took off again and was fine. then it just quit completely. the solenoid would click 1 time when u hit the trottle and never again. switch it off and back on and it would click once and not again. had 48 volts on everything. change solenoid and now it want switch on at all. HELP please.
BOBCU2
I have a 2007 Yamaha and it has the same problem .... it would lurch forward and then stall... keeping foot on pedal it would start up again and run a short distance..., I corrected the problem the first time by putting it in the tow position for 15 minute. but 1 week later i am back with the same problem.... help
Welcome to the forum.
Usually the problem you describe is a bad controller if all the cable connections are clean and tight. You can try jumping the 2 large posts on the solenoid with a 6 gauge or bigger cable and see if the problem goes away. If it does the solenoid is bad. If the problem is still there while jumping the solenoid I'd say it's the controller.
timr495
thanks for the help i took to a man but still not fixed. i ve thought it was the controller. wheres the best place to get the controller? HELPPPPPP
BOBCU2
I have the same problem and had Yamaha Service Company come out and they thought it was motor, replaced it .... came back a week later with new motor and still had problem.... so they replaced controller with no good results... checked wiring ... o.k. batteries... o.k. could it be the solenoid? They took my cart into shop to check it out....
BOBCU2
I finally had the Yamaha Dealership take my cart in to have it checked out and was told the wiring harness as well as the motor was bad.... It is now working... I had the company return my burned out motor... On examining motor found two of the brushes were worn real bad.... cause, the housing holding the 2 bad brushes were defective they held brushes so tight that they wold not flout in place which caused them to wear out prematurely. Has anyone else had this problem... It sound that this could be a major problem with the 2006 Yamaha . This was why cart would run a short distance then hesitate and stall....
