Having a short issue with my Yamaha Drive 2 lights and turn signal. As long as I don’t touch the light or turn signal it will start. Each time I move it the horn blows and the 10amp fuse blows the cart dies. Help
Lol thanks for the input..Working the meter ..has not found anything yet I got it running with headlights last night but the lights didn’t seem as bright as I started buttoning things back up tried the lights again and the horn started again for no reason. So hunt continues
Like Nubs said these kind of electrical problem can be a pain to fix. I'd look closely at all of the lights and horn wiring to see if you can find a frayed wire or bad connector that could be shorting out. Also look at any grounds and make sure they are all good. Good luck amd let us know what you come up with.
Welcome to the forum.
