can anyone help me get this kawasaki wired up ?? i have the wiring diagram but im not understand how to go about the wiring can anyone tel me which wires go where? also how can i post the wiring diagram on here where someone can explain it to me..
i've done the fd620's, are ya working with full harness from something else and tryin' to adapt it? is the cdi bolted to the block or loose. you can load the diagram on photobucket, etc and post from there.
ive got a complete motor with wiring and all and i stripped all my stock wires out of mine and from what ive read you have to wire it up just how it says with the diodes and all or you will fry the ecu. and everything is bolted tothe motor like its suppose to. nubs can i email you its still trying to set my up an account and its taking forever
Yes you are right nubs there's a 3 plug and i white wire and then a 6 plug I think and then the relays and a couple diodes and I bought some just not understanding how to wire this all the up. Also I can't seem to find a ignition switch with an A B C D E like it shows
