Won't start unless I pull the choke out!!
Every time? hot/cold. have you checked the valve clearance, what is the compression?
dirttoo
Mine just started that last week after sitting about a month. I pulled the carb and there was a rust chunk blocking the main jet. runs great now.
country
check the spark plug and check your throttle linkage rod to make sure that it is opening the butterfly
