D dcoleman New Member Jun 21, 2011 #1 I backed my cart up and when I put it in forward it moved just a little and now won't move forward or reverse. Any idea's?
HotRodCarts Cartaholic Jun 21, 2011 #2 Welcome to the forum. Is this a PDS or series cart? Does the reverse beeper still work when you put the cart in reverse?
D dcoleman New Member Jun 21, 2011 #3 Ther reverse beeper is disconnected but still works when reconnected. I don't know the difference between a PDS and a Series cart.
HotRodCarts Cartaholic Jun 21, 2011 #5 I'd start with checking all the cables and cable connections to make sure they're clean and tight. Can you here the solenoid click when you try to move the cart?
D dcoleman New Member Jun 28, 2011 #6 Sorry for the delay, yes wires are clean and tight. Solenoid clicks and replaced to see if that was the problem.
