Wiring Upgrade/State of Charge Meter
cladkr81
Hello,
I am looking to replace the 6gauge wiring in my 2003 EZ Go Txt with 4 gauge. I believe I need to do this because of a couple issues. The cart seems to go slow after a full charge and starts shuddering up hills. After a full charge the total voltage 38 V .
Does anybody know a good place to get the wiring from? Does it come with the connectors or do I have to crimp them on?
Also looking for a state of charge meter. My cart does not have one and i would like to install but I am not sure what is required and the difficulty level.
Help!
MrWicked
how do you know its a full charge????
to install the meter is real easy install 2 wires and cut a hole in the dash for the mounting of the metter
Andy4639
The cables aren't going to help you with the shuttering. That's a battery issue. You need to put the cart batteries in a loaded position and see what they read. Sound as if you have at least one or 2 batteries going out.
cladkr81
What is considered a loaded position? After a charge?
I will measure total again and individual readings for each battery.
Thanks
