pyratebill
I bought a very used 1993 EZ Go cart last spring. I used it last season with little or no troubles. A few weeks ago I had a problem that started like this. I would be parked and when I tried to hit the accelerator to go forward I would hear the solenoid click and that was all. I could then put it in reverse and it would engage the motor. Then I could put it back in forward and drive as per usual.
This went on for a few days until finally I get no movement in either F or R. As I said I hear the solenoid click in both directions but no go.
I removed the seat to take a look and make sure there were no obvious broken wires etc. I found a wire that is obviously broken off at the lug but I cant tell where it is supposed to go. I downloaded a wiring diagram and the diagram is a little less that perfect in that it really doesn't show all wires and all possible connections.
The wire in question is a white wire (may be original) that comes off of the bottom of the F - N - R switch.
What do you think my next step is?
See pics at:my photobucket golf cart pics
Click the pics to read my descriptions.
Thanks for looking!
Thanks for looking!
