Will only start without exhaust
Sarviss3
I have a 1990 ez go. I just replaced the piston, rings and cylinder. I also replaced the fuel pump. It will not start with the exhaust on it. It will try to start and fire a little bit without it, but you can not give it much pedal. I did replace the carb with one off the internet but I think that's junk , so I'm going to look for a new one. Any help would be greatly appreciated
Hard to tell if it will not run at all, if the cart has not been run in a long time and the compression was low then 99% chance the seals are bad. new seals are just part of the deal with 2 cycles:twocents:
