will not run
bluegt
new batteries,cables,electrical checks out good, when you push the pedal all the way down it starts to jump like low batteries,put a meter on the batteries still reading thirty five volts. it creaps very slowly no speed, help please.
spr
35 volts fully charged? fully charged they should be a little over 36 volts. put the volt meter on and try pressing the gas and tell us how much it drops. how old are the batteries?
fabbinman
make sure all your connections are clean and tight. Don't forget the ones on the motor as well
shadowman
if its dropping to 35 volts thats your problem, go over every cable connection and get the batteries fully charged and than load test them...................................
