Why Does My 95 Club Car DS Move As It Starts?
LostinBaja
Why does my 95 Club Car DS move as it starts? If I put a couple people in the cart it has trouble starting because of the extra weight.
I've had this problem since I rebuilt the engine. I changed the belt, moved the engine as close to the driven clutch as it will go and rebuilt the clutch.
What am I missing?
Most of the gas carts I've had or worked on will move as they start. If the golf cart is having trouble starting with extra weight I'd start with testing the battery.
LostinBaja
Does anyone know anything about the kits that contain a relay and a clutch spring that allows the cart to start and Run/Idle as long as the key is on. Then allow the cart to be put in gear and driven.
All the vendors are out of the kit but I'm sure that I could source the components if I had the info. Anyone?
LostinBaja
I finally got the chance to work on the cart again....I rebuilt the drive clutch and all is good. I think the spring was worn out since it was considerably shorter than the new replacement spring.
