what year? 1992 to early 96 the ignitor is bolted to the rear of the bracket that holds the rpm limitor on which is a small black box located under the carb over top the oil drauin plug.........later 96 the ignitor is built into the coil its a coil ignitor combo which is mounted left side of motor under plastic shrould just follow the spark plug wire and where it disapears thats where the coil is...............................................
