Where Do you Find the Fuse Box on a Club Car Precedent
aokjerry
Blew a fuse while installing a battery gauge on a 2010 Club Car Precedent but can't locate fuse box. Must be a main fuse, cart won't even go now.
Any help available?
Thanks, Jerry
Hi ?, No, realized after my mishap that I should have done that and I wouldn't of had a mishap. But my problem now is I've looked all around, and under the cart and can't find the fuse box and can't find anything on You Tube showing where it is only that it's "Easy to locate". Anytime in the past when I've had a problem like this I'd look on Y T and find 10 different videos with a guy showing you exactly where to look.
Thanks for your input.
Jerry
Same problem here....Good afternoon.. Novice mechanic here. I was installing a battery meter in the dash and I accidentally shorted out something. Batteries have power and the 15 amp in line blade fuse is intact. it seems like a blown fuse somewhere. I joined the forum because I saw a previous post on an older model that had the same problem. Just know where to look.. nothing on the dash works, no reverse buzzer, but when I plug in it charges. Not sure what I fried. Thanks in advance.
Thanks,
Just did all of that and found a blown 15 amp fuse, so now I have power to the dash but reverse button doesn't buzz, which I don't think there is power to this portion. Could it have blown more than one fuse?
Well Darn I was hoping you would be able to walk me through this as we have very similar issues. I installed a battery meter and USB port into a 2011 got everything buttoned up and tested no issues noticed that a tail light was not working and when I pulled the light a poorly crimped connector came apart and shorted against the frame.
