Dexterjr16 New Member Oct 13, 2020 #1 How do you fix the axle so it doesn’t rub on the wheel when I drive ? What piece do I need to stoppi the wheel from rubbing the front axle?
HotRodCarts Cartaholic Oct 13, 2020 #3 It could be bad wheel bearings, bad king pin bushings or a bent spindle causing the wheel to rub the axle.
S Shootrig Cartaholic - V.I.P. Oct 16, 2020 #4 Can you edit that pic with two arrows - one pointing at what is being scored on the tire/wheel and one showing the piece that is touching the tire/wheel. I think I see what you’re showing, just want to confirm
