Westinghouse Golf Cart Solenoids
luverofvicki
new to electric carts, I have an older Westinghouse 36 volt golf cart. The three lower solenoids have been replaced, I need to know if the upper solenoid is the same or different. It is old and there are no visible numbers. thanx
Without knowing most likely the same check the voltage going to it and threw it Is the voltage the same as the other ones
