While I'm asking questions here......I recently purchased a Warne Winch for the front of my Cart. (I toasted the made in China one that was on there. (Short story.....plastic gear thing)
Now, my previous winch was simply wired to a 12-V auto battery that just runs the winch (from a switch on the dash....and this will work the winch if the key is on or off) and the 12-V Battery also feeds the headlights when I "click" the key to the second position.
The Warne came with a safety device that you can wire into a 12-V system (my cart is 48-V) where you hook the 12-V positive wire to one side of the key, and the ground to a negative, and the winch will only work when the key is on.
Now, I do not want to wire this into the light switch as I don't want to have the lights on when I need the winch. (Draw too much power from the little 12-V)
Any ideas as to how I can hook this up to work with the key?
Dave
Dave
