voltage reducer
havman
Does anyone have a diagram of wiring for a voltage reducer on a 1991 marathon 36 volt cart?
Purchased lights and reducer but no directions for the reducer hookup. Also I should probably use fuse block?
havman
The only thing I can find on this is oc29 it's an aluminum case and says that it will take juice from all the batteries at the same time. May be it's a voltage converter.?????????? purchased on ebay under sellerr ms922 purchase number is 350206278619 it says voltage reducer. It has black red wire out of bottom and orange black out of bottom in different area. Appreciate any help you can give me. Thanks Jim
