voltage reducer VS 2nd battery
thefuzz
OK guys got another question to ask of you ? I'v ben reading some post wher some guys instead of puting a voltage reducer on there cart to run the lights,sterio,exctra they put a 12v battery on it just for that purpos an charge it seperatly i'v ben weighing the pros an cons of both price v/s price SO ! GIVE ME SOME FEED BACK ON THIS !!!!!
thanks !
thefuzz
WOW! thanks for your input APARENTLY NO ONE ELSE wants to give there commint on the subject or keeping there opinion to them self ? I probly going to go with the x-tra battry since I can't see the advantage of the reducer x-cept not haveing to seperate charge a battry!
THANKS TO ALLL WHO REPLY TO MY POST YOU"V HELP ME ALOT !!
I guess I'm not paying these guys enough to spend 24/7 on the forum to make sure everyone get questions answered.
Usually if the tech questions are asked in the tech forums instead of the drivers club forum they get answered right away.
And thanks to the guys that take the time to help people with questions...
I agree with GarageBuilt on running the accessories of a separate battery.
GarageBuilt
Well-Known Member
You have 3 choices
#1. The voltage reducer ....Works off of two batteries in your battery pack causing it to become UN balanced..... Not good for your battery pack !!!!! Keeping your pack balanced will take a lot of work..
#2. The voltage Converter... Works great off the entire battery pack but not big enough to work lights radio winch all at the same time... Before you buy one compare the amp draw from your accessories then compare the amp draw that the converter can handle....
#3 The 12-volt deep cycle extra battery.... Can handle lights radio plus a little more..... For extreme power you can run two extra batteries in parallel.... And can still be charged with one 12-volt charger ....
