Voltage converter
DDavis6384
I am installing a voltage reducer in Yamaha Drive. 48v down to 12v.
should I wire it directly to the batteries or run it through the ignition switch somehow? Seems like “always hot” may be a problem. Thanks,
Doug
golfcar2000
Most of them are designed to hookup to battery pack, but may depend on the brand you have. Did it come with a diagram?
DDavis6384
Thanks for responding.
I have an instruction sheet that simply says input+ to batt+ and input- to batt-. But on a golf cart, will power full time to converter over heat it, or run batteries down when cart is not in use?
