2001 EZGO
I swaped engines & put a 570 vanguard briggs & stratton engine in. My question- the green wire that goes to the starter... is the starter on this engine also a generator? If so, where does the green wire connect on the starter, also there is a terminal coming off of the engine that may be alternator/magneto (sp?) what wire & where should this connect?
I have the engine running, but when I turn the key off, it stays running? Any ideas- separate kill-switch??? How will this engine charge the battery.
Any help or direction, would be appreciated.
Thanks~
Thanks~
