gornoman
Well-Known Member
The cart started acting different. I noticed that whenever I turned the key ON, I would hear the solenoid click. Never did that before. Also, leaving the cart sit would heat up the solenoid if the key was left on and the cart was in gear (something that might happen if you were to stop at another campsite and sip a beverage while sitting in the cart yapping on the edge of the roadway). I suspected the ITS microswitch had failed.
Simple job, and I will replace the jumper with a new switch next week.
