Andrew Duke
I have two carts and hope to make one running cart. I have an older EZGO TXT that has bad rust on a few spots on the frame. I was planning to weld some new metal to the frame to repair it but I just got a new project. I got a Bad Boy Buggie that also needs some repairs. I was told that a Bad Boy Buggie is an EZGO fame with a slightly different body and two motors to enable 4WD. Upon looking at the BBB, the frame appears to be the same as the TXT. The BBB rear wheel was sheared off and what appears to be the spindle is broken in the axle. I am having a problem finding parts for the BBB and was hoping I could use the wheel/ axle assembly from the TXT to repair the BBB. The TXT is a 36v and the BBB is a 48v model. Does anyone have any experience with BBB repairs or any links to where I could get parts for the BBB? I really dont need a 4WD cart but the BBB frame and body is in better shape than the TXT so its easier to try and use parts from the TXT to fix the BBB. Any help is greatly appreciated.
