Twin Motors
Thanks Guys ...I cant say things are going great but I well get it all worked out...
Rod should the axle hanger be in line with the chassis hanger Or offset out a little...I'm talking about the hanger's that holds the 4 bars... :dazed:
Terry this is the cart were going to slip you into at OP's next race if your drag cart is not ready.... So, make peace with the world Sir.... If you want it to purple then you will need to bring 3-4 purple spray cans...
Very impressive GB....thanks for sharein and keep pushin that envelope.....it's gonna pay off...you'll see.. :checkered:
Looking good Ronnie, it's coming along nicely.
For the 4 link yes the brackets should be in line. The bars should be 90 degrees of the axle tubes. You could probably run them on a slight angle as long as both sides are exactly the same angle but if you have the room run them straight.
Lookin' good Ronnie!!!
Make sure those 4-link bars aren't bound up in the brackets and that you have room for them to move up and down in the brackets. :twocents:
