Troubleshoot
donlsandy
WHEN I PUSH DOWN ON THE GAS PEDDLE OF MY 1993 CLUB CAR THE STARTER TURNS OVER AS LONG AS THE PEDDLE PUSHED, BUT THE MOTOR DOES NOT START. CHECKED GAS FLOW,SPARK PLUG. SOMEONE TOLD ME IT MIGHT BE THE IGNITOR AND THE IGNITION COIL. I LOST NEED HELP
Welcome
well if it has spark its not the ignitor or coil. does it have compression?
shadowman
have you tested to see if it has spark? thats the 1st thing don,t assume a new plug will cure it, if you have spark than gas.....take the hose off at carb and crank over see if your getting gas to carb, than compression.............you can take the spark plug out spray some carb cleaner in there put plug back in and try...if it runs you have a fuel problem..........................................
