Trouble With Aligning Wheels and Cam
Kvmcphail
I have a 2017 Club Car. I adjusted tie rods and the onto cam. Everything seemed to adjusted fine. Then we turned around quickly and everything goes out of whack again. I'm sure everything is tightened down. Don't know what to do now.
You more than likely have worn bushings maybe even bearings and what cam are we talkin about
Kvmcphail
Thank u for responding,
Just replaced bushing recently, I should have said CAMBER adjustment but I don't think that is it. Measurements are perfect. I've narrowed down to passenger side wheel keeps popping out of line every time I drive and put tension by turning on that wheel. Nuts are tight. Don't know much about checking bearings.
