I recently changed out cables on 48 volt club car. Now Cart will not charge. Would like a wiring diagram. See if I did not get wiring back the way it should be.
When you changed cables did you run the new one through the OBC like the old cable was? If not it won't charge. There's a wiring diagram in the Club Car Resource forum...
Think, hell I know what the trouble is now. I did not unhook the batteries in the proper way before I did any of this. Now my question is: Is there a way to reset the OBC or did I fry it? If I did....what kind of cost am I looking at to fix/replace the on board computer? Thanks, this idiot could sure use some help.
I'm taking it you didn't flip the run tow switch to tow when you changed the cables? Was there any sparks when you replace the cables? There's instructions in the Club Car Resource forum here for rebooting the OBC.
Went through the procedure to reset the OBC on my golf cart. This did not work/??????????
If the OBC needs to be replaced, what kind of cost am I looking at?
