Tomberlin E-Merge 2 Slowing Down
daflabear
I have a Tomberlin E-Merge 2 that is about 18 months old and has about 2900 miles. Recently it started slowing down and barely gets up to 20 MPH.
My dealer put in two new batteries and i still is running sick. Does anyone else have this problem or know the proper fix???
Welcome to the forum...
What you describe sounds like a bad battery(s). Has your run time gotten shorter? After the next charge take individual voltage readings on the batteries. Ride the cart an hour and take the voltage reading again. Post your results.
You don't need to unhook any cables to take the voltage test.
daflabear
Hi HotRod,
My dealer checked out all six batteries and found 2 that that were bad and have been replaced. Still didn't solve the problem.
These Tomberlins are still getting the bugs worked out and most dealers do no have enough experience with them to troubleshoot very much.
A lot of dealers don't know how to test batteries either. :cool: If it was me I'd do the voltage tests just to be sure. It's suprising that two batteries were bad in only 18 months...
