TIRE SIZE
matt75
AFTER LOOKING AT MY CART IVE DECIDED THAT 22" TIRES JUST WONT CUT IT WITH A 14" LIFT
WHAT IS THE LARGEST TIRE YOU CAN RUN ON A STOCK FLEET CART WITH OUT CAUSING AMP DRAW OR EXTREMELY LOW TORQUE PROBLEMS. I DO PLAN ON UPGRADING THE WIRE SIZE AND GOING FROM 36V TO 48V.
THANKS
MATT
I usually stick with 22"-23" when using the stock controller. If you go with a higher amp controller I'd say 25".
My silver cart has 22" Strykers and if I air them up to 20+lbs they measure about 24" and I've had no problems with the stock motor and controller. I do have HD buss bars and 4 guage cables.
I've seen electric carts with 27" but they were highly modified carts. It all depends on how much money you're will to spend.
matt75
THANKS HRC, IM GOING TO TRY TO SELL MY 22" TURF TRACS OR TRADE THEM FOR A LITTLE BIT LARGER TIRE. I FIGURE IVE GOT THE ROOM, WHY NOT.
