06z400rider
Hey guys, I have a tech question: I have converted two different carts to 48 volts in the last couple of months- both EzGo PDS carts '06 and '07. I tried to purchase the automatic ezgo chargers (Thunderbull brand because they're cheap.) They were out of stock on EzGo chargers both times. I instead ordered a club car charger for the 48 volt powerwise and the ezgo DC cord ends. When they arrived, I cut off the club car end and installed the ezgo end with only the white and black wires plugged up. It charged fine, but it never sensed the battery pack's presence, and it was on all the time when plugged up to AC voltage, even when not plugged to the cart. I then realized I hadn't hooked up the green sensor wire inside the EzGo plug end. I hooked it up, and when I plugged it into the cart, you could hear the relay click inside the charger, like it does on a regular powerwise. I then hooked it into the AC voltage, it charged fine, but it still never shuts off, and it has been overcharging the batteries. Once voltage gets to 56, the cart won't drive unless I somehow drain the voltage a little. I.E.: turn headllights on for a few minutes, and then it takes off once voltage is below 56. I have two brand new chargers that I really cant sell to customers unless I find a way to make the automatic shutoff work on them. They are supposed to be automatic chargers, but they are set up for Club Cars, so I don't know if an EzGo relay board or something like that would enable the auto shutoff??? I know this is a very technical question, but I figure someone on here may be able to answer it... Any ideas?
