throttle
jsmith6752
1998 GX444 throttle plate the throttle plate is not fully closing. The spring that allows the throttle to open also is not allowing it to return fully closed. I have looked for a diagram to see if there should be a return spring. Does the throttle plate not open some when adjusting the idle screw? I have the same issue with backfires as many others. I have adjusted the cable as well. I would like to find a diagram with the correct parts listed. The other cable (below the throttle cable is not hooked up at all. It would appear someone has unhooked it for some reason. Your thoughts wouls be appreciated...thanks
